Riyazs
Aug 06, 2019Aspirant
C3700 is rebooting when i try to enable WIFI
My C3700 WIFI is automatically disabled. It shows Yellow Warning sign as WIFI is turned-off in Web page. When i try to enable/go to advance settings, its rebooting. I pressed the second butoon from top (WIFI) for more than 5 seconds, nothing happened. Has anyone experience the same?
What happens if you factory rest and modem and setup from scratch?
- RiyazsAspirantIt does same when I tried to enable WIFI post factory reset. Internet is working fine when connected to cable but WIFI is disabled.
I would open up a support ticket here and get more help from NG:
https://www.netgear.com/mynetgear/registration/login.aspx
Ask about an RMA.
