Jul 07, 2022Aspirant
C3700 modem wifi shows 5GHz, how do I get the modem to also give option of the 2.4. I
Jul 07, 2022Guru - Experienced User
When you log into the C3700, have you set the ssid's separate on 2.4ghz and 5ghz?
Is the status screen showing them broadcasting?
Did it change or is the C3700 a new purchase?
