martye
Feb 23, 2017Follower
C3700 N600 router - 2.4GHz stopped working (5GHz and wired are fine)
I have a C3700 N600 router that up until today had been working fine. My 2.4GHz connection was spotty at best, and when it did connect was at least an order of magnitude slower than normal (and than...
seanvig
Mar 01, 2017Aspirant
I have the same problem. Everything was working fine until Nov 8 2016 (election night, belive it or not). Started having difficulties connecting then. Frequently had to do factory resets of the modem. Then a few days ago the 2.4 band stopped allowing connections from any device. Have tried hard resets, factory resets, etc to no avail. Any help appreciated.
TheEther
Mar 02, 2017Guru
Try changing Wi-Fi channels. It's possible that there are too many active Wi-Fi networks and/or too much radio interference around you for 2.4 GHz to be usable.
