franco910
Jun 02, 2019Aspirant
C3700 N600 Speed issue
Spectrum upgraded our area for 200 mbps. However I checked the speed with an ethernet cable and it was only 100 (my pc has gigabit ethernet). I contacted spectrum and they said their info says my e...
- Jun 03, 2019
I got impatient waiting on an answer so I went ahead and bought the nighthawk router modem combo. So far so good. Getting 1 Gbps LAN and 300 mbps Wifi. Crazy fast. Not sure I believe it. I didn't get a chance to try your solution but thanks for replying. Maybe it can help others.
Jun 03, 2019Guru - Experienced User
Power OFF the modem for 1 minute. Then back on. Reboot your PC while the modem reboots to ready. Check speeds.
franco910 wrote:Spectrum upgraded our area for 200 mbps. However I checked the speed with an ethernet cable and it was only 100 (my pc has gigabit ethernet). I contacted spectrum and they said their info says my equipment is only good to 100. However if you look at the netgear specs it 300, What gives?
- franco910Jun 03, 2019Aspirant
- FURRYe38Jun 03, 2019Guru - Experienced User
Thought you already had this modem router combo?
Mark your post as solved so others will know.
Ok, Enjoy. :smileywink:
I had the C3700 N600 but was having the issues previously stated so I bought the newer AC1900 and it works like a charm. I'll mark the post as solved but I never actually tried your solution on the C3700 because it was already disconnected when I got your message. Thanks though.
