franco910
Jun 02, 2019Aspirant
C3700 N600 Speed issue
Spectrum upgraded our area for 200 mbps. However I checked the speed with an ethernet cable and it was only 100 (my pc has gigabit ethernet). I contacted spectrum and they said their info says my e...
- Jun 03, 2019
I got impatient waiting on an answer so I went ahead and bought the nighthawk router modem combo. So far so good. Getting 1 Gbps LAN and 300 mbps Wifi. Crazy fast. Not sure I believe it. I didn't get a chance to try your solution but thanks for replying. Maybe it can help others.
Jun 03, 2019Guru - Experienced User
Power OFF the modem for 1 minute. Then back on. Reboot your PC while the modem reboots to ready. Check speeds.
franco910 wrote:Spectrum upgraded our area for 200 mbps. However I checked the speed with an ethernet cable and it was only 100 (my pc has gigabit ethernet). I contacted spectrum and they said their info says my equipment is only good to 100. However if you look at the netgear specs it 300, What gives?
franco910
Jun 03, 2019Aspirant
- FURRYe38Jun 03, 2019Guru - Experienced User
Thought you already had this modem router combo?
Mark your post as solved so others will know.
Ok, Enjoy. :smileywink:
- franco910Jun 03, 2019Aspirant
I had the C3700 N600 but was having the issues previously stated so I bought the newer AC1900 and it works like a charm. I'll mark the post as solved but I never actually tried your solution on the C3700 because it was already disconnected when I got your message. Thanks though.
:smileywink:
