NET3700User
Jan 02, 2019Follower
C3700 OCCASIONALLY DROPS CONNECTION
I have a Netgear C3700 and it keeps dropping the wifi connection. I would have to directly connect my laptop to C3700. This is for home use and both the laptop and C3700 are located in the same roo...
C3700_wifi
Jan 03, 2019Aspirant
I have the same issue. Last night, the device stopped giving out a wifi signal completely. I can connect to the network with a cable. But the wifi signal doesn’t show up on any device, even though the wifi led light is lit on the device.
I have tried restarting it multiple times. I don’t know what to do. Please help.
- Cherrytree1352Jan 22, 2019AspirantMy 2.4 worked the first day we had it. Then hasn't worked since, if there is no fix it will be going back.
