NET3700User
Jan 02, 2019Follower
C3700 OCCASIONALLY DROPS CONNECTION
I have a Netgear C3700 and it keeps dropping the wifi connection. I would have to directly connect my laptop to C3700. This is for home use and both the laptop and C3700 are located in the same roo...
C3700_wifi
Jan 03, 2019Aspirant
I have the same issue. Last night, the device stopped giving out a wifi signal completely. I can connect to the network with a cable. But the wifi signal doesn’t show up on any device, even though the wifi led light is lit on the device.
I have tried restarting it multiple times. I don’t know what to do. Please help.
Cherrytree1352
Jan 22, 2019Aspirant
My 2.4 worked the first day we had it. Then hasn't worked since, if there is no fix it will be going back.
