ksean
Aug 07, 2015Follower
C3700 Qos
I purchased a C3700 modem/router. How do I set up QoS on it? According to the NetGear docs any device with the Genie interface should have a QoS option under Advanced > Setup. But I don't. My firmware version is V1.01.05, which I think is the latest because NG says there's no way to manually update it.
But I work from home and also use MagicJack for my phone. I want to prioritize my MJ device as sometimes phone calls are choppy while I'm on my VPN.
Thanks.
- DarrenMSr. NETGEAR Moderator
Hello Ksean
I went and checked the specs of the c3700 and it does not have QOS at this time.
DarrenM
- KHowlAspirant
What alternative options are available?
KHowl
You may be able to google for some programs that can limit bandwidth to certain devices.
DarrenM
- JohnCallAspirant
Hi, sorry about restarting this conversation... I also have a need for QoS. Can you confirm if the CM600 [1] will allow end-users to define custom QoS policies? For example, I would like to create a policy that prioritizes the IP addresses (2) of my VoIP telephone and cellphone femtocell (Verizon device that requires an internet connection.) I'm currently using a C3700, and have call issues (garbled, dropped calls, etc...) when my kids are watching Netflix.
[1] - http://www.netgear.com/home/products/networking/cable-modems-routers/CM600.aspx#tab-techspecs
Thanks,
John
