InTheSprings's avatar
InTheSprings
C3700 router becomes inaccessible after several hours. DHCP?
Hello,
seeking expertise. After several hours of the router functioning properly, the router becomes inaccessible via 10.0.0.1 -- whenever I restart it, it becomes accessible but goes down again after several hours.  What is causing this?
Recently I have:
Added an external drive via the USB.
Enabled guest networks.
Disabled SSID on home and guest networks.
I appreciate your help to resolve this matter as it is requiring I power off/on the router every day.
  • michaelkenward's avatar
    michaelkenward
    The C3700 is a cable modem router, not just a router. The "footer" on your message refers to the WNDR3700, which is a router. So it isn't clear what the layout of your network looks like.
    You should check that you have started the network in the correct order. The Quick Start guide for the modem explains this:
    >>> C3700 | Product | Support | NETGEAR <<<
    • InTheSprings's avatar
      InTheSprings
      You're correct. The correct model is C3700. The template would not let me enter that model.
      I should mention that this is a new issue, I've had this product for about 5 months and the issue began in the last 30 days, this is why I mentioned what I had done as of late. It has the latest firmware. Also, internet continues to work on all devices on my map, but I cannot access the router's interface from any, via wifi or ethernet. Thanks for your reply.
        michaelkenward
        InTheSprings wrote:
        ...but I cannot access the router's interface from any, via wifi or ethernet.
        If this is your problem, then you are one of many users who face the "cannot login to router" issue.
        There are many conversations along those lines. There is, though, no single solution.
        You may find it instructive, if a little tedious, to search the forum for some of those discussions.
        As your internet connection seems to be working what is it that you want to do with the router?
