mags90
Apr 22, 2019Follower
C3700 Router Not Providing IP Address
Hi All,
I've been having issues with hooking my router up to my PC. I'm currently OCONUS for work and using a campus provided internet. I can sign into my internet and use it just fine without the ...
Apr 22, 2019Guru - Experienced User
You state you're on campus provided internet. this could be your problem right there. I don't know your campus connection setup but some don't allow this. I'd check with your campus IT department to see if this is something they allow and the best way to implement it.
Reason I mention this is my campus didn't allow routers/AP's/etc connected to their networks. An unmanged switch would work. Anything with managment/routing function, wouldn't work. (might have got in a bit of trouble trying to force it to work)
Save yourself some headache and contact the IT department for your campus providing the internet service.
