mags90
Apr 22, 2019Follower
C3700 Router Not Providing IP Address
Hi All,
I've been having issues with hooking my router up to my PC. I'm currently OCONUS for work and using a campus provided internet. I can sign into my internet and use it just fine without the ...
JoseAndres041
Apr 24, 2019Luminary
I agree with plemans . Your device is a WiFi cable modem router. It needs cable connection to get Internet access. You should be getting a regular router (like R7000) instead of this model. Anyway, if you just want to know if your device can't provide an IP address, you could disconnect your C7300 and just connect it directly to your PC. Reset your device to factory default (press the reset button for 30 seconds) and once it fully boot up, do an ipconfig. Check if you can get an IP address now.
