Ryan0
Apr 21, 2020Aspirant
c3700 Secruity Question after Factory Reset
After pressing the reset button in the back, http://192.168.0.1/ asks me for serial number which I provide then asks me to answer two secruity questions. I didn't set any questions. I keep trying to ...
Apr 21, 2020Guru - Experienced User
are you pushing and holding it until the lights flash? usually 7-15 seconds?
have you tried a different pc/browser?
- Ryan0Apr 21, 2020Aspirant
Yes. Held it until green light flashed again.Tried different browser as well.
Sometimes it doesn't even let me go to the serial number page
- plemansApr 21, 2020Guru - Experienced User
Make sure the coax is unhooked when you do it.
Try a different pc and hardwire into it .
also try going to 192.168.100.1
