Nick540R
Dec 31, 2021Tutor
C3700 WiFi Intermittent Internet Connection Issues - Spectrum Internet Provider
Hello, I've been having internet connection issues for about 3 weeks. The internet is working fine, then I lose connection. Typically, I turn the modem off and then back on, and everything is f...
Dec 31, 2021Guru - Experienced User
1. does it happen on wired devices AND wireless or just wireless?
2. do you have a screen snip of the cable connections page and the event logs? That helps us check the connection back to the ISP
- Nick540RDec 31, 2021Tutor
Thank you for the response.
1) I only have wireless connections. Not sure I have a LAN cable to connect to anything
2) How do I see those pages so I can provide a screenshot?
Thanks, again!
