Nick540R
Dec 31, 2021Tutor
C3700 WiFi Intermittent Internet Connection Issues - Spectrum Internet Provider
Hello, I've been having internet connection issues for about 3 weeks. The internet is working fine, then I lose connection. Typically, I turn the modem off and then back on, and everything is f...
Dec 31, 2021Guru - Experienced User
1. does it happen on wired devices AND wireless or just wireless?
2. do you have a screen snip of the cable connections page and the event logs? That helps us check the connection back to the ISP
Nick540R
Dec 31, 2021Tutor
Thank you for the response.
1) I only have wireless connections. Not sure I have a LAN cable to connect to anything
2) How do I see those pages so I can provide a screenshot?
Thanks, again!
- plemansDec 31, 2021Guru - Experienced User
- Nick540RJan 02, 2022Tutor
Thank you. I'll work to abtain this information and post the screenshots.
To be continued...
Hi, could not connect using the link in the two links you provided. Error as shown in the attached.
- plemansJan 03, 2022Guru - Experienced User
so you're not able to log into the router at all?
have you tried factory resetting and reinstalling it?
