justme007
Oct 04, 2020Aspirant
C3700 WIFI XFINITY SLOW. PLEASE HELP!!
C3700 cable modem/wifi router xfinity comcast internet provider latest firmware speeds today running speedtest right noxt to router 120Mbps download speed ethernet to pc 15-20Mbps download WI...
wcalifas
Oct 04, 2020Prodigy
Make sure your password algorythims are set to WPA2-TKIP AES on both bands and when you do the speed test try it real close to the router.
- justme007Oct 05, 2020Aspirant
received this message following your instruction
WPA-PSK(TKIP) operates at up to 54Mbps (legacy G) mode not N mode. NETGEAR recommends
that you use WPA2-PSK(AES) to get full N rate support.also you said to test near router but that doesn't help as I want FAST WIFI speeds throughout the house.
- wcalifasOct 05, 2020ProdigyWpa2-psk (aes) yes that's what you should use. No router will give you those speeds from far away unless you're hard wired to it.
- justme007Oct 12, 2020Aspirant
i tried changing the security method as suggested. I also changed channels based on avaialbility. ISP said there is no new firmware to push out.
no change the wifi is so slow.
. ANYONE have any other suggestions? how did yuo fix the slow WIFI?
- justme007Oct 06, 2020Aspirant
I already have the routet set at WPA2-PSK(AES)
wireless speeds are extremely slow next to router or not.
does anyone have ANY other suggestions?
