hjjr78
Jul 02, 2022Aspirant
C3700v2 – N600 WiFi Cable Modem Sudden Issues
I've noticed my router had a firmware update because the admin screen doesn't look exactly the same. I am not getting a lot of 408 type errors when trying to open a webpage...basically, I'm getting ...
- Jul 05, 2022
I found a solution....
For starters, I didn't even know my lan connection was off and I was using all router-modem wifi the whole time since I got with Xfinity. The wifi has issues, there's no denying that, but things went back to normal once I enabled my lan connection and started actually using the ethernet cable I had running from my Netgear to my PC.
So now I'm not getting the 408s, pages not loading in or lagging in, under my lan connection. The only other issue I had was the website I'm building wasn't working under lan but I solved that by making changes in the Netgear port forwarding.
I do have wifi usage concerns still because my Firestick uses the 5g channel and my PC was using the 2.4g wifi channel. Since the lan connection uses the 5g, that places both the Firestcik and my PC on the 5g, which means if somebody is watching a movie or gaming on the Firestick, there could...maybe be bandwidth conflict....maybe not.
Anyway, my Firestick is the only thing that seems to use the wifi just fine on the 5g. I don't really use my phone for internet while at home, so I can't really say how bad the webpage loading will be using the wifi for that device or the pad.
Conclusion...
Use the local network (lan) computer connection with a Netgear router-modem combo, if you're on the PC that the Netgear runs to with the ethernet cable or other cable. If you're on a PC that is not connected directly to the Netgear and you have to use the wifi...
You're in serious trouble because what people were saying on Amazon about my Netgear model losing wifi stability over time, was obviously no lie! I bought it because the overall review rating was not that bad but clearly...Netgear has some issues as a brand.
PS, that warning at the top of my Netgear Admin page about not being connected to the internet is gone. Yay!
Jul 03, 2022Guru - Experienced User
the C3700v2 is a modem/router combo device and isn't users updatable. You can check your firmware version versus what's supposed to be current.
did you ever try a factory reset on it? Maybe an old setting is causing issues.
Do you have a screen snip of the cable connections page and event logs?
