x9
Jul 18, 2022Tutor
C3700v2 - firmware on admin screen is later than the latest version offered by Netgear?
I've been having constant issues with this device for over two months now. The device will encounter connection issues at odd times and usually reboot itself 2 - 3 times a day. It seemed to happen ev...
- Oct 31, 2022
The service provider had to make three trips out to my residence but they eventually replaced the entire line and the connection has been consistent. Appears it had nothing to do with the firmware.
If anyone encounters this in the future please be sure the technician inspects the line inside your house, outside to the pole, and also across the road if your line warrants that. The first tech replaced the line from our house to the pole and declared success. We had signal issues 30 minutes after he left. The second tech found signal issues and shorts with the line from the house entry point to the modem so he re-did that and declared success, and then we had signal issues 30 minutes after he left. The third tech found signal issues in the cable leading from the bup pole across the street to the main pole, so he replaced that and the splitter box where all the other neighbors tap in. I'm not sure how you ensure the tech does this because they'll get offended if you scrutinize their work, but I just wanted to stress the importance of a comprehensive analysis of the entire line.
Jul 18, 2022Guru - Experienced User
the wndr3700v2 and the c3700v2 are 2 different products. They won't have the same firmware.
Who's your isp?
What actual issues are you having?
Do you have a screensnip of the cable connections page and the event logs?
x9
Jul 19, 2022Tutor
Sorry that was a typo and I see now I was visiting the wrong page. I do have the C3700v2 and after seeing this page I see that the ISP (Spectrum) has provided the latest firmware. Here is the info from the Cable Connection screen:
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 405000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Configuration File | OK | |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Override MDD | IPv6 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | QAM256 | 23 | 405000000 Hz | -0.1 dBmV | 41.4 dB | 2332 | 2708 |
| 2 | Locked | QAM256 | 24 | 411000000 Hz | -0.2 dBmV | 40.8 dB | 2165 | 2468 |
| 3 | Locked | QAM256 | 27 | 429000000 Hz | -0.1 dBmV | 41.4 dB | 1916 | 2187 |
| 4 | Locked | QAM256 | 28 | 435000000 Hz | -0.2 dBmV | 41.3 dB | 1879 | 2770 |
| 5 | Locked | QAM256 | 30 | 441000000 Hz | -0.3 dBmV | 40.9 dB | 1864 | 2450 |
| 6 | Locked | QAM256 | 31 | 447000000 Hz | -0.3 dBmV | 41.3 dB | 1941 | 2659 |
| 7 | Locked | QAM256 | 32 | 453000000 Hz | -0.2 dBmV | 41.3 dB | 1992 | 2610 |
| 8 | Locked | QAM256 | 33 | 459000000 Hz | -0.2 dBmV | 41.4 dB | 1783 | 2377 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 89 | 5120 Ksym/sec | 17600000 Hz | 46.3 dBmV |
| 2 | Locked | ATDMA | 90 | 5120 Ksym/sec | 24000000 Hz | 47.3 dBmV |
| 3 | Locked | ATDMA | 92 | 5120 Ksym/sec | 36800000 Hz | 49.5 dBmV |
| 4 | Locked | ATDMA | 91 | 5120 Ksym/sec | 30400000 Hz | 48.0 dBmV |
Current System Time: Tue Jul 19 09:16:00 2022
