x9
Jul 18, 2022Tutor
C3700v2 - firmware on admin screen is later than the latest version offered by Netgear?
I've been having constant issues with this device for over two months now. The device will encounter connection issues at odd times and usually reboot itself 2 - 3 times a day. It seemed to happen ev...
- Oct 31, 2022
The service provider had to make three trips out to my residence but they eventually replaced the entire line and the connection has been consistent. Appears it had nothing to do with the firmware.
If anyone encounters this in the future please be sure the technician inspects the line inside your house, outside to the pole, and also across the road if your line warrants that. The first tech replaced the line from our house to the pole and declared success. We had signal issues 30 minutes after he left. The second tech found signal issues and shorts with the line from the house entry point to the modem so he re-did that and declared success, and then we had signal issues 30 minutes after he left. The third tech found signal issues in the cable leading from the bup pole across the street to the main pole, so he replaced that and the splitter box where all the other neighbors tap in. I'm not sure how you ensure the tech does this because they'll get offended if you scrutinize their work, but I just wanted to stress the importance of a comprehensive analysis of the entire line.
x9
Jul 19, 2022Tutor
I'm not sure these event logs encompass the time frame I experienced the outage but next time I have an issue I'll be sure to note the time.
| Time | Priority | Description |
| 2022-07-19, 08:49:43.0 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 05:21:45.0 | Warning (5) | MDD message timeout;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 05:21:00.0 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 05:21:00.0 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 05:20:50.0 | Notice (6) | Overriding MDD IP initialization parameters; IP provisioning mode = IPv6 |
| 2022-07-19, 05:20:43.0 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.0;CM-VER=3.0; |
| 2022-07-19, 05:20:28.0 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 04:11:39.0 | Warning (5) | MDD message timeout;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 04:10:50.0 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 04:10:50.0 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 04:10:37.0 | Notice (6) | Overriding MDD IP initialization parameters; IP provisioning mode = IPv6 |
| 2022-07-19, 04:10:31.0 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.0;CM-VER=3.0; |
| 2022-07-19, 04:10:17.0 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 04:10:17.0 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 04:10:17.0 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 02:32:11.0 | Warning (5) | MDD message timeout;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 02:32:10.0 | Warning (5) | MDD message timeout;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 02:32:10.0 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 02:31:23.0 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 02:31:23.0 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 02:31:12.0 | Notice (6) | Overriding MDD IP initialization parameters; IP provisioning mode = IPv6 |
| 2022-07-19, 02:31:05.0 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.0;CM-VER=3.0; |
| 2022-07-19, 02:30:50.0 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-19, 02:16:28.0 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-18, 12:51:09.0 | Warning (5) | MDD message timeout;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-18, 12:50:36.0 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-18, 12:50:36.0 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-18, 12:45:29.0 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-18, 12:43:12.0 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-18, 12:41:34.0 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| 2022-07-18, 12:41:12.0 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:ba:27:98;CMTS-MAC=00:01:5c:6c:a0:51;CM-QOS=1.1;CM-VER=3.0; |
| Time Not Established | Notice (6) | Overriding MDD IP initialization parameters; IP provisioning mode = IPv6 |
Jul 19, 2022Guru - Experienced User
You have errors in the line and the logs indicating line issues.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
- x9Oct 31, 2022Tutor
