Nov 30, 2019Follower
C3700v2 The LED internet light wont connect what is the problem
1 Reply
That doesn't tell us much.
1. What isp are you using?
2. Do they support the C3700v2?
3. have they initialized the modem to your service?
4. What does your modem connections page show? (take a sceen snip of this)
5. What does your modem logs show? (again with the screen snip)
6. More details on whats going on. is this a new setup, old setup that worked, basically the more info you give us the better. We're not in your location so we don't know whats going on and the less you tell us, the less we can help.
Here's your support site with manuals and install guides.
https://www.netgear.com/support/product/C3700v2
