ssteers
Nov 27, 2019Follower
C6220 - Network not showing up on available connections
I have no wireless connection even avialable for me to connect to. All of a sudden it just stopped working last night. I contacted my ISP support and they said that it was something to do with the mo...
Redhot1980
Feb 22, 2020Aspirant
I am having the same issue. I called my service provider and everything on their end is fine , the only thing that my WiFi will work on is my tv , because it is hard wired . My cell phones and my fire stick does not show my router name. An anyone help with this issue plz . Thanks
- FURRYe38Feb 24, 2020Guru - Experienced User
So does the wifi SSID appear in the wifi list on your TV? Can the TV connect to the modem with it's wifi if you disconnect the ethernet cable?
