herecuzitbroke
Jan 14, 2021Aspirant
C6220 5Gz suddenly stopped working
Our router has been working fine for 2 years. Then the 5Gz networks disappeared from both the home network and the guest network. Can't see the SSID from multiple devices. 2.4 works fine. We've tried ...
Jan 20, 2021Guru - Experienced User
Any progress on this?
herecuzitbroke
Jan 27, 2021Aspirant
Unfortunately, no. We concluded that the most likely explanation was a hardware failure.
- FURRYe38Jan 27, 2021Guru - Experienced User
Try a factory reset with the coax cable disconnected from the modem...
