turincj
Dec 12, 2022Aspirant
c6220 configured in bridge/no router mode. How do I access the c6620 configuration
Once I've turned off routing in my c6220 how do I access it's configuration? Putting http://192.168.0.1 in a browser window of a PC that's directly connected via ethernet cable just returns an error...
- Dec 12, 2022
Thanks for the help. I did visit the link you gave but it doesn't say anything about that address 192.168.100.1. Once you turn off the router, the 192.168.0.1 address no longer is accessible. I looked and looked for the answer but never encountered anything that suggested the 192.168.100.1 option. Thanks for providing that - I'm in.
Dec 12, 2022Guru - Experienced User
Does 192.168.100.1 work?
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
turincj
- FURRYe38Dec 12, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. 📡
