SJH13
Feb 13, 2021Aspirant
C6220 Frequent Wifi disconnects and/or modem crashes
Issue: Modem/Router goes offline frequently from twice a day to twice a week. Firmware on the Modem/Router V1.02.11. Xfinity Service package: Internet only, Performance Select 100mbs The cab...
Natedeeeez
Feb 23, 2021Aspirant
I’ve been having the same issue. Random disconnects. I noticed that right before the issue occurs, there are a ton of “uncorrectables”. My ISP has confirmed the signal is very strong but something needs to be fixed in the modem/router. Netgear, is there a firmware update to fix this inconsistent and unstable connection???
SJH13
Feb 24, 2021Aspirant
Natedeeeez No one has ever even looked at, much less replied to my inquiry. There are, in fact, quite a lot of people, in the past who have had this exact problem. Somehow they got responses, but not me, apparently
I gave up on ever getting any help from Netgear and my ISP, which is Xfinity.
Instead, what I've done to solve the issue was to purchased a TP Link router. Then I went into the settings on the Netgear Modem/Router and turned the Wifi function OFF and simply am using the Netgear product as a modem, and the TP link as the router.
So far at least (it's been over a week) I have NOT lost wifi. Before I did this, the Netgear Modem/Router was dropping the Wifi every few days, sometimes twice a day. So, this might have solved the issue. This is the second Netgear combination Modem/Router that has had frequent failures, the other one was a NETGEAR CM1150V that I ended up returning to Netgear, because of the constant crashes. Personally, I won't buy another combination modem/router, especially one from Netgear. Good luck to you.
My advice, try any other brand than Netgear. They clearly have quality control issues now, and abysmal support, which is a shame, because for 25 years, I've only bought Netgear.
