heliac
Sep 16, 2021Aspirant
C6220 Intermittent internet connectivity Issues
Hello, I am having internet connectivity issues that are sporadic. The connection will be fine and then it will drop and there will be no connection at all and then it reconnects on its own. This...
heliac
Sorry for teh double post but it only let me attach one file.
The event log is here.
Sep 16, 2021Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
