TechNotsavvy111
Mar 16, 2020Follower
C6220 Netgear Router Power
While I was away, my wifi stopped working. Upon coming home, my router was plugged in, turned on but all the lights were off and was not giving off a wifi signal. I tried unplugging it for a couple of...
Mar 16, 2020Guru - Experienced User
You could try replacing the power supply or if you happened to have a matching one around, you could try that. Just make sure it has the same voltage, polarity, and at least the same amperage. You can have a higher amperage but you don't want to go lower.
