netto1
Jul 07, 2020Aspirant
C6220 network connection issue
What would cause devices all on the same network to loose their connection between each other but each still maintain their connection to the internet? Restarting the router always fixes the issue. ...
Jul 07, 2020Guru - Experienced User
- netto1Jul 07, 2020Aspirant
Channel is set to manual.....I don't see how that would matter since all devices can connect to the router and maintain an internet connection?
- FURRYe38Jul 07, 2020Guru - Experienced User
Any Wifi Neighbors near by? If so, how many? There maybe some wifi interferences or noises in your surroundings that may be causing problems.Has a factory reset been performed and setup from scratch yet?
Also try setting up IP address reservations for your devices ON the modem.
BTW...the same thing can happen whether using either 2.4 or 5.0 The channels on 2.4 I tried include 1,6,9 and 11. Again, why would this have anything to do with it when each device is able to maintain its internet connection though the router?
