nathancameron
Feb 08, 2024Aspirant
C6220 not showing 5ghz
Alright so last weekend I was out of town and came back to find the 5ghz internet option is not longer showing up. 2.4ghz has no issues connecting but is noticeably slower.
I've tried to factory reset, I've done all of the power cycling that I've done as solutions in the past to other issues, but nothing is fixing this. All lights are solid on the modem/router itself, but the 5ghz isn't broadcasting out.
I've seen other solutions on here but none of these are fixing my problem. Desperate for some help.
- nathancameronAspirant
Also, forgot to add that it's running V1.02.31 firmware
Try a 30-30-30 reset on the modem with it disconnected from the ISP coax line and all other LAN cables disconnected. Then walk thru the setup wizard with a wired PC and web browser.
If this fails to bring back the 5Ghz signa, time for something new.
Could put this gateway into bridge mode and use the modem portion and connect up something external or use this gateway in router mode and disable all wifi radios on the gateway and connect up something new externally in AP mode.- nathancameronAspirant
I can give the wired reset a try, but I'm not convinced it'll make a difference considering all of the other resets that I've done based on other posts here with similar issues.
Probably time to get a new one, considering this one is about 3.5 years old at this point - I've noticed it runs pretty warm when it's on so I'm wondering if that's a sign to get another as well.
Probably. Time for something new. I recommend separate units, modem and external wifi router system.
