Dank321's avatar
Dank321
C6220 Open NAT for Ps4 gameplay
Hello, as the subject says I am looking to change my NAT type on my C6220 router to open (type 2 or 1) for my ps4. I had type 2 using it wireless, however I recently got an ethernet cable to get bette...
  • FURRYe38's avatar
    Nov 22, 2020
    Power cycle the modem and PS console...
    Try a factory reset of the modem and setup from scratch with the PS wired to the modem.
