Dank321
Nov 20, 2020Aspirant
C6220 Open NAT for Ps4 gameplay
Hello, as the subject says I am looking to change my NAT type on my C6220 router to open (type 2 or 1) for my ps4. I had type 2 using it wireless, however I recently got an ethernet cable to get bette...
- Nov 22, 2020
Power cycle the modem and PS console...
Try a factory reset of the modem and setup from scratch with the PS wired to the modem.
Nov 22, 2020Guru - Experienced User
Dank321
Nov 24, 2020Aspirant
Much to my surprise power cycling actually worked! Guess that's why you are a guru eh? Thank you so much for your help! I wonder how many other things I can fix by simply turning it off and on again... 🤔
- FURRYe38Nov 24, 2020Guru - Experienced User
Glad that worked. Enjoy. :smileywink:
