Dank321
Nov 20, 2020Aspirant
C6220 Open NAT for Ps4 gameplay
Hello, as the subject says I am looking to change my NAT type on my C6220 router to open (type 2 or 1) for my ps4. I had type 2 using it wireless, however I recently got an ethernet cable to get bette...
- Nov 22, 2020
Power cycle the modem and PS console...
Try a factory reset of the modem and setup from scratch with the PS wired to the modem.
Dank321
Nov 24, 2020Aspirant
Much to my surprise power cycling actually worked! Guess that's why you are a guru eh? Thank you so much for your help! I wonder how many other things I can fix by simply turning it off and on again... 🤔
Nov 24, 2020Guru - Experienced User
Glad that worked. Enjoy. :smileywink:
