JTG22
Nov 25, 2020Aspirant
C6220 What's the far right LED light on the face of the modem indicating? Mine has never lit up
Nov 25, 2020Guru - Experienced User
Check the User Manual for info.
Probably WPS.
- JTG22Nov 25, 2020Aspirant
What's the WPS used for??Far right light is never on
- FURRYe38Nov 25, 2020Guru - Experienced User
It's a one button press on the router and your new wireless device(s) that you maybe adding to the system. Press buttons instead of using a SSID name and PW to get the device connected. Only seen on WPS devices that support that feature though. Not all devices have WPS.
