DOVERPRO35
Jul 18, 2022Tutor
C6230 - MY ROUTER/MODEM ALWAYS SEEM TO RUN VERY WARM TO THE TOUCH.
MY ROUTER/MODEM ALWAYS SEEM TO RUN VERY WARM TO THE TOUCH. I HAVE SEEN INTERMITTANT TIMES WHERE THE MODEM IS NOT CONNECTING AND BOOTS BACK UP AFTER A PERIOD OF TIME WHEN I HAVE SHUT IT DOWN AND COOLE...
Jul 18, 2022Guru - Experienced User
1. caps lock. please uncheck it. Thanks
2. do you have a screensnip of the cable connections page and event logs?
3. what actual temp does it run at?
4. You put its rebooting, does that happen even with the fan pointed at it?
5. is it in a well ventilated area?
6. Is anything blocking its vents?
- DOVERPRO35Jul 18, 2022Tutor
nothing is blocking the venting, sits by itself. Have not taken its temp, just know it is hot to touch. I can keep my hand on it but only for a bit.
Do not have a screenshot, not sure how to get that. The fan is a new idea to keep it cool and it has not needed to be rebooted in last 24 hours since implementing
- plemansJul 18, 2022Guru - Experienced User
Usually not a good sign for longevity if its running that warm.
If you log into the router through the browser, click on the internet icon on the home page/basic. It'll take you to the cable connections page.
find the event logs this route: https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Netgear is sending me a replacement as it is under warranty.
