blusworld
Jul 25, 2022Aspirant
C6230 AC/1200
I have a C6230 AC/1200wifi cable modem router. I have had for about a year. I have to unplug power cord every time to use for it to work properly. It works fine and then when I come back an hour l...
Jul 25, 2022Guru - Experienced User
do you have a screen snip of the cable connections page and event logs?
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
- blusworldJul 29, 2022Aspirant
My old setup was a modem and a router. The C6230 as you know has the modem and router as one unit. When I hooked up the new unit, I found that I had something hooked up on the one Lan slot that I did not need. I removed the connection, and everything works fine.
Thanks for your help.
