akgrown99
Mar 04, 2022Follower
C6230 Connection Issues
Hi Everyone, I have a C6230 with Xfinity as my ISP. I have been having the following issues recently: My Xbox Series X will not connect to the internet via ethernet and I have to restart the...
Mar 08, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Is the devices wired or wirelessly connected to the modem?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
