Ethan69420
Feb 01, 2023Initiate
C6230 requiring reboots during large file tranfers
since buying this modem new it always loses connection to the internet during large downloads. its finally bothering me enough to reach out. ISP: Optimum event log.
Feb 01, 2023Guru - Experienced User
Sadly thats just the standard bootup log. It clears on reboot for most devices.
Do you have a screensnip of the cable connections page?
also, have you noticed if it happens when done over wifi versus wired?
And 2.4ghz vs 5ghz?
- Ethan69420Feb 01, 2023Initiate
Seems to happen wired or wireless but I normally use the 5ghz connection.
- plemansFeb 01, 2023Guru - Experienced User
Wow your signal is coming in hot. It should be between -7.5dbmv and 7.5dbmv. You're over 15.
You need a signal attenuator in line. That hot of a line would cause reboots easily.
