Ethan69420
Feb 01, 2023Initiate
C6230 requiring reboots during large file tranfers
since buying this modem new it always loses connection to the internet during large downloads. its finally bothering me enough to reach out. ISP: Optimum event log.
Ethan69420
Seems to happen wired or wireless but I normally use the 5ghz connection.
Feb 01, 2023Guru - Experienced User
Wow your signal is coming in hot. It should be between -7.5dbmv and 7.5dbmv. You're over 15.
You need a signal attenuator in line. That hot of a line would cause reboots easily.
