tlee
Feb 03, 2016Aspirant
(C6250-100NAS) Slow http traffic
My setup was working fairly well for about six months until http traffic came to a crawl this week. All clients behind the router have very slow web access over http (essentially unusable), however ...
DarrenM
Feb 04, 2016Sr. NETGEAR Moderator
Hello Tlee
First I would check your cable connection if your modem on a splitter if so try removing that and go directly to the wall. If that was not the issue you might want to do a ping test to check and see if you are having packet loss. it could be some bad connection from your ISP out to the internet. Try this website to test. Last thing you can do is contact your ISP to make sure the connection is good and there is not high traffic happening in your area.
DarrenM
tlee
Feb 05, 2016Aspirant
Darren,
Thanks for your thoughts. I did check the coax and tightened it for good measure. Unfortunately, pingtest was not reachable because of the problem symptoms. I had Xfinity send refresh signals a few times, but it had the same result as the factory resets -- the first time helped for about 30 minutes, but subsequent refreshes did not help.
I rented an Xfinity gateway yesterday to help isolate the issue. I'm getting smooth performance with the Xfinity gateway so I have to conclude that the C6250 is failing on me.
The C6250 2.4GHz network traffic bogged down about a month ago (while 5GHz continued to operate normally) so I assumed that it was a defect isolated to the 2.4GHz hardware. I got around it by hooking up a travel router AP for 2.4GHz access. That setup worked well up until this week. It feels like whatever defect was afflicting the 2.4GHz network has now crept into the 5GHz and wired networks.
-Tommy
- DarrenMFeb 05, 2016Sr. NETGEAR Moderator
Tlee
If you found the modem was defective and it is still under warranty I would then contact Netgear support which I linked to see if the unit needs replaced.
http://support.netgear.com/general/contact/default.aspx
DarrenM
