Net83
Aug 04, 2017Aspirant
C6250 5 GHz Not working - NO Light, No Signal, Not found in Wireless Settings
Its been less than a month and the 5GHz Not working. I tried resetting to factory setting. After restart, ONLY 2.4 GHZ light is ON. 5 GHz Light is NOT ON. Logged in to NETGEAR Genie console...
- Aug 07, 2017
I called customer care. They asked me to power off and power on, reset to factory settings and finally asked to remove the coaxial cable while the power is on and then remove the power cable. They put it back in the same order.
None of the above steps worked. 5 GHz light did not come back ON.
Finally they confirmed that the product is defective and asked me to return and get a new one.
Net83
Aug 07, 2017Aspirant
vkdelta
Aug 08, 2017NETGEAR Employee Retired
Please PM me.
