Garyeagle
Jan 10, 2020Aspirant
C6250 AC1600 Modem Router Download stream lightning bolt keeps flashing.
I have had this modem/router for about one and a half years and was connected to the Comcast TV router. Just recently I turned in the TV router and plugged the cable into the C6250 modem/router and ...
Garyeagle
Jan 16, 2020Aspirant
The manual states, on the blinking green downstream lightning bolt means the unit scanning for additional downstream channels...
- FURRYe38Jan 17, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.Try a factory reset and setup from scratch on the modem.
- GaryeagleJan 17, 2020AspirantComcast has tested the line in and said it showed good signal strength and quality.
I have done a factory reset and it is still happening.
Occasionally the signal drops out on my phone which uses wifi for connectivity.
This started after i disconnected the cable tv and returned the equipment to xfinity, and just signed up for wifi.
It is supposed to be downloading up to 175gbps. But I'm showing about 85gbps.
Could the modem have gone bag, or not be able to handle the speed? It's not what the specs say...
Thank you for your help...- FURRYe38Jan 17, 2020Guru - Experienced User
You might get a newer modem and see if the modem works any better than what you have. Possible the modem has or is going bad.
