Garyeagle
Jan 10, 2020Aspirant
C6250 AC1600 Modem Router Download stream lightning bolt keeps flashing.
I have had this modem/router for about one and a half years and was connected to the Comcast TV router. Just recently I turned in the TV router and plugged the cable into the C6250 modem/router and ...
Garyeagle
Jan 17, 2020Aspirant
Comcast has tested the line in and said it showed good signal strength and quality.
I have done a factory reset and it is still happening.
Occasionally the signal drops out on my phone which uses wifi for connectivity.
This started after i disconnected the cable tv and returned the equipment to xfinity, and just signed up for wifi.
It is supposed to be downloading up to 175gbps. But I'm showing about 85gbps.
Could the modem have gone bag, or not be able to handle the speed? It's not what the specs say...
Thank you for your help...
Jan 17, 2020Guru - Experienced User
You might get a newer modem and see if the modem works any better than what you have. Possible the modem has or is going bad.
