dpwct
Feb 27, 2022Aspirant
C6250 cable modem router very slow 2.4
I have a Arlo camera that only works on 2.4ghz And it has been failing to send recordings to cloud Tested speed on 2.4 and 5 GHz and saw a dramatic difference 5ghz 110/50 2.4ghz 0.85/3 Usin...
Feb 27, 2022Guru - Experienced User
Try a factory reset and setupi from scratch on the modem.
try setting manual channel 1, 6 or 11 on 2.4Ghz
Ensure WMM is enabled on the modem. Setup 40Mhz only Under Advanced Tab/Advanced Settings/Wireless Settings
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems (C and CM series) products:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
