LukeTeiger
Jun 23, 2019Follower
C6250 Issues
Got home from vacation and I am unable to connect to the WiFi. I called the provider and they said everything looks good on their end. When I reset the Router I only have 4 lights that stay on. The power button, the downward pointing lightning bolt, the 2.4, and the 5. Any help would be greatly appreciated. Do I need to replace the router or is there an easy fix?
1 Reply
What does the user manual say about the LED behavior?
Do you see any SSID names on a device at all?
