MathMXC
Aug 05, 2017Aspirant
c6250 modem router telnetenable
I am trying to connect to my c6250 router using telnet. I have followed all of the steps listed on github as well as on open wrt. I did not see my router on the list of known devices so I assumed tha...
vkdelta
Aug 06, 2017NETGEAR Employee Retired
that script does not work C6250.
they are locked up for security reasons.
MathMXC
Aug 07, 2017Aspirant
I thought that the c6250 had the exact same router portition as the r6250. Am I wrong? Also is there any way to bypass those security restrictions?
- vkdeltaAug 07, 2017NETGEAR Employee Retired
no, C6250 is a combined chipset for Cable and Router.
there is no way for customers to bypass restrictions.
also, you wont find those settings even if you telnet since C6250 does not run Linux for Cable/Gateway portion. so you wont have anything to tinker there
