armkobi
Sep 21, 2020Aspirant
C6250 no longer connect PS4 to internet with LAN cable
I've using my modem for months, connecting internet with LAN Ethernet cable to the PS4, but since a few days, suddenly stops connecting through LAN cable, so I had to change to WiFi. Now I can't set ...
Sep 22, 2020Guru - Experienced User
Is ANY other device having issues connecting to the router?
usually when its only 1 device having issues connecting, it isn't the router. It tends to be the device.
Are you using access control/parental controls on the router?
armkobi
Sep 24, 2020Aspirant
My laptop is working with no problem
