cgd0505
Oct 15, 2018Follower
C6250 strange VPN problem
I'm at my wits end here with this issue - I work from home and connect to my company's network using a VPN (Cisco AnyConnect). I have Xfinity internet and my own C6250 modem/router combo. I can conn...
Xargos427
Feb 13, 2019Aspirant
Router: AC2400 from Best Buy
Load: V1.2.0.36_1.0.1
Bought: Jan. 2019
Hi, I found a turn around to that problem on my AC2400
If you can live with a less efficient firewall (according to Netgear), remove the NAT filtering whyle you are using the Cisco Anyconnect VPN. Works fine with me. Note that I had no problems whatsover with my old Cisco router. Exact same set-up.
Go to advance setting, WAN set-up, remove NAT filtering
I have been working a full day without any dropping, everything is accessible. So, looks like the Anyconnect VPN doesn't like to run on competitor material
While it is easy to me to switch between NAT or No NAT because I am using the Cisco VPN only once a week, I can live with it for a while.
However, I was on the edge of trowing the Netgear away. On the bad side Cisco branded routers don't exist anymore. Linksys? Cisco commercial spin-off. Don't know
X.
