igace1
Sep 28, 2020Aspirant
C6250 Wifi Dropping With Strong Signals
My wifi connection has been dropping every minute or so. I currently have the C6250 cable modem router. My firmware is V1.02.01. My provider is comcast. The router is directly connected to the coax ...
igace1
Sep 29, 2020Aspirant
Thanks for the reply! I'm on channel 1 for 2.4 Ghz and 36 for 5 Ghz. Unfortunately I live in a large building so have quite a few wifi neighbors (20+). I have done a factory reset but it didn't make a difference.
Sep 30, 2020Guru - Experienced User
Try channels 6 or 11.
Do you have any power output adjustments under Under Advanced Tab/Advanced Settings/Wireless Settings?
- igace1Oct 06, 2020Aspirant
Sorry for the late reply. I did switch to channel 6 but it didn't make a difference. I don't have anything listed for power output adjustments in any of my settings.
