Wynter26
May 11, 2022Aspirant
C6250 will not connect
No matter what I do it just won’t work. I can’t access it through Wi-Fi because obviously it’s not working but that seems to be the only way through the nighthawk app.
michaelkenward
May 12, 2022Guru - Experienced User
So, you need help with an C6250 modem/router?
What does "won't work" mean? It cannot connect to the Internet? Something else?
Take us through what you are doing and where it goes wrong.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
Manuals are also a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
