Wynter26
May 11, 2022Aspirant
C6250 will not connect
No matter what I do it just won’t work. I can’t access it through Wi-Fi because obviously it’s not working but that seems to be the only way through the nighthawk app.
michaelkenward
May 12, 2022Guru - Experienced User
So, you need help with an C6250 modem/router?
What does "won't work" mean? It cannot connect to the Internet? Something else?
Take us through what you are doing and where it goes wrong.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
Manuals are also a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
Wynter26
May 12, 2022Aspirant
Hi, thank you for reaching out. The lights are flashing so it seems like the power is working. The issue I’m running into is my ISP and the Nighthawk app cannot connect to it at all. I’ve tried unplugging and replugging but that didn’t work. I’ve tried factory resetting by using the button on the back but that doesn’t work. When I try to use the app with Wi-Fi on I’m unable to sign in for some reason (password is not the password). I’m just really confused because it used to work until upped my service speeds.
- plemansMay 12, 2022Guru - Experienced User
Are you able to access it by connecting to the wifi and using a browser (not the app)
- Wynter26May 12, 2022AspirantI’ve tried through my ISP and the app but since neither will connect to the modem itself I can’t access the Wi-Fi. Unfortunately, where I live the signal without Wi-Fi is very spotty so I’m kind of in a standstill.
You can't connect to the wifi at all?
then you might need to borrow a laptop or buy a usb/ethernet adapter to hardwire into it to access it
