davidbjbrooks
May 09, 2022Follower
C6300 – AC1750 WiFi Cable Modem Router. i bought used works good . but i cant log in ! to change
May 09, 2022Guru - Experienced User
What error are you getting?
did you factory reset it and install it yourself?
To reset, push and hold rest for 7-15 seconds while powered on
then follow the install guide.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
