psj8890
Dec 26, 2017Follower
C6300 – AC1750 WiFi Cable Modem Router Wifi disappeared
Wifi Router C6300 – AC1750 WiFi Cable Modem Router Wifi disappeared. After restart the modem router, Wifi can be found and worked for a while then it suddenly disappeared from the wifi list and not ...
DarrenM
Dec 28, 2017Sr. NETGEAR Moderator
Have you tried to rename the network? or notice when the network goes away that a certain device is connecting to the network?
DarrenM
prasanths1989
Jan 02, 2018Aspirant
I am frustrated with this issue. My both 2.4 & 5 wifi is getting dissapeared from all devises frequently.
Router shows all lights on. But network is disconnected and disappeared from all devises such as Laptops, Google Home, Alexa, Cloud Cam etc.
I tried reset modem/router but didn't help.
If I restart Modem/Router it will connect properly.
What is happening here? Any Solution?
